Opinions on C-notching frame
badblackram06
MS
My ram is lowered 2/5. I want to get some 2inch lowering spindles then i want to lower the rear some more. The rear end is already like a few inches from the frame and very seldom hits but since i want to go lower I'm going to have to do the c-notch. Would any of you guys do it or do you have it done?
I've been getting "dont do it!" because it totals out the truck if the insurance ppl find out. But i'm also hearing if its done right it wont even matter. I was just wondering what you guys thought about it.
OklaHemi
new age hemi
for the sake of ride quality on a truck that low i believe it is necessary. i dont think it would total your truck if it were done right by a shop. in your back yard with a 30 pack ehhh. i would do it and hopefully will do it one day, when i can afford new wheels and tires and air bags and everything else. call an insurance agent or a professional shop and ask them.
AF_Hemi
Central Jersey in person, the burgh at heart
2013 Ram 1500 CC 4x4 Sport
agreed. as far as strength goes, if done properly it will be every bit as strong as the original frame. as for whether or not your insurance company would like it, ask them
RubberFrog
ride quality will improve
your insurance WILL total it if they find out
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
I don't have a notched frame but I'm sure I will before it's finished. I haven't asked the insurance company, so can't say but I doubt if it would automatically "total" a truck having it done professionally. This doesn't mean not doing it yourself, but more about the quality of the build. I say go for it.
OklaHemi
new age hemi
so let the ins total it and buy it back a t a cheaper price and money in hand
Redtruck-VA
Virginia
There would be an issue of you purposely totalling your truck in that case.
I dd ask my insurance guy about what compensation I could expect for my truck if it was damaged and suggested that I have it apraised to establish it's modified value and get a custom builders policy.
OklaHemi
new age hemi
damn ins always trying to hold a man down. if that is purposely totalling your truck and would be fraud, then how are they allowed to sell them? even for off road use.
OklaHemi
new age hemi
here is a number from aribagit.com they should be able to answer, they are the seller
Need help call 800-842-8789. Before you buy, read Knowledge Base under RESOURCES on the Left C-sections Frame notches to keep axle from hitting bottom of frame. Never cut frame until you assure there is no Pressure on the frame before cutting. Use jackstands in front & Rear
kay9
Banned
xxxx
xxxx
Total of the truck is ok as you will still some type of insurance payout. I am actually more nervous in getting declined due to darker tails if something happens.
badblackram06
badblackram06
MS
You all have some good points. I'm going to call the insurance ppl tuesday and see what they have to say about it. If they dont like it i may just call around to some other insurance companies and see if they would cover modified frames.
OklaHemi
new age hemi
its a common practice. someone would cover it
Redtruck-VA
Virginia
That would really bite, might be good to stick with DOT certified lights. Same with a roll pan if we got rear ended, you know the insurance will at least make noise about not having a bumper. And certainly not cover the custom body work and tailgate. Reason why I'm thinking builders insurance.
DHPmike
Wylie, Texas
I have a tech article on this with pics. If anyone wants me to post it just say so and you can check it out and see what you think for strength and such.
Coley 1334
Garland, Tx
dont be scared to cut on the frame a lil lol my noch on my truck is about as bigg as u can go without having to cut the bed :roflsquared:
ride so much better on my 2/4 i will never bottom out now and i made it out of 3/16
Armor plate so it wont bend when i get rear ended :naughty:
OklaHemi
new age hemi
that looks awesome
Redtruck-VA
Virginia
Yes that is nicely done.
I was thinking using the heavy wall pipe and a piece of 2x2 square tubing on top of the frame.
DHPmike
Wylie, Texas
actually insurance will cover all of that. If someone else hits you then you just need to show what it cost you and what the vehicle is worth.
I had a cover truck, completely hand built get hit and they tried to give me 1600 bucks because of blue book. I showed the magazine proving worth, plus what I spent and got 4300.
Coleys Dodge has been hit twice and he made out like a bandit both times without having to fight much either time.
remember its your vehicle and you have the right to let whatever place fix it. In my case I said I would fix it, or get some estimates from hot rod shops. It was an easy decision for them.
DHPmike
Wylie, Texas
We made that notch at the place we work. We both work at Integrated Armor and build armored vehicles. We have access to a CNC plasma and the CAD program to design anything. We also build Ranch Hand style bumpers so we also have access to 4.5" OD tube for regular old school C notches.
The one on Coleys truck is called a "super C" and fits .250" under the bed floor. It slides down over the frame and then welds in so you dont lose any strength there.
Redtruck-VA
Virginia
Mike, good information is always welcomed. Please post what you have.
Thanks,
