SRT10 rear on my Hemi?
LightningRaper
Brooklyn NY
Viper 8.3
Hey guys I'm in the middle of tubbing out my 06 SRT10 so I now have a complete oem srt10 rear with rotors and brakes with 4:56 gears. I was originally just going to keep brakes and rotors for my 05 Hemi daily driver but I've been thinking of just swapping rears completely. What would I lose and what would I gain? I know it's been done before but don't know much about the swap or what's involved. Would I need a new drive shaft? I do tow with my hemi, mostly just atvs.
S2kiHemi
Houston TX
You won't really be losing anything. Larger calipers/rotors, 4.56 gears and LSD are all positives. Only negative I can see is if you drive a lot on the highway then you might get 1-2 mpg less depending on what gears you have new. The 4.56 gears will be much better for towing.
I thought about swapping in the SRT rear end in my old 05 Hemi and you did have to have a custom drive shaft made.
LightningRaper
LightningRaper
Brooklyn NY
Viper 8.3
Are leaf springs the same? Anyone that has done this before have drive shaft specs?
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Question, what rear end are you using with the tub?
LightningRaper
LightningRaper
Brooklyn NY
Viper 8.3
It's a narrowed strange 60, it was actually on the truck "Tinygiants" but that truck got wrecked so I bought the rear, I have changed the setup a bit, moving the mounting brackets inwards and doing longer bars for the 4 link, this project is also requiring me to cut the bed, notch my frame, custom made rims (tires 20" wide), and a fuel cell
Sybil
I can't wait too see this! What size wheel/tire are you going with on the rear?
Statcher1
Kentucky
Sounds like your trucks a beast. Good luck and post up some pics when you get done
LightningRaper
LightningRaper
Brooklyn NY
Viper 8.3
33X22.00R20LT Micket Thompsons with 20" rims
OLD TIRES VS NEW
Because of this build is why I have a spair srt10 rear for my hemi
LightningRaper
LightningRaper
Brooklyn NY
Viper 8.3
Back to the original post, if anyone has done a srt10 rear in their hemi id love to hear about it
TylerB
FL
Otneil did it on his red qc hemi and also added the T56 along with it. As far as I can remember the axle was a straight swap except for the driveshaft.
LightningRaper
LightningRaper
Brooklyn NY
Viper 8.3
He did a t56 too? Don't tell me this I have a spair t56, clutch, flywheel, and shifter bezel off a truck I parted. But then again I already converted my QC srt10 maybe I will leave the hemi auto, maybe not
LS5DodgeRam
South Florida
4.7L v8
If you manage to find a way to spin those tires... then you sir are crazy for horsepower
TylerB
FL
Yeah he did, I'm really jealous he did too. It's easy to keep the 3rd gen's computer happy, the 4th gens no so much. I dream of a T56 in my truck...
LightningRaper
LightningRaper
Brooklyn NY
Viper 8.3
With my srt10 when I converted to t56 I put in tune from a regular cab as they are 6 speed with t56, what tune would I put in hemi if I went t56
TylerB
FL
A tune from a Hemi 2500 with manual transmission. You would lose MDS though.
