I currently have the adjustable Bilstein 5100s on my truck, running a 275/65/20 on the stock rims.
I have a couple questions on what could be done to run 35-12.5-20 on an aftermarket rim.
From what I have read i should set the Bilsteins up all the way. As far what rim specs I should get is where I am stuck at. Would like to know what would work...20x9, 20x10 with a -12mm or -24mm offset.
Any input would be great. Been doing some reading on the forum and elsewhere, but can't really find anything that suggests what wheel specs to run.
