1" rear steel lift block?
BgHrn
IL
While I was checking my rear brakes, I noticed that the r/r steel lift block is cracked right down the middle. Do they still make a 1" rear steel lift block? I've checked all the "usual" 4wd sites, and I've come up with nothing. Anybody help me?
xb1230
Hobby Mechanic
South Shore of Montreal, QC, Canada
Blocks aren't the best of ideas...
You usually want your springs (or leafs) sitting as close to the axle as possible.
Helps prevent wear and twist on the leafs and axle perches.
Just saying !
