3 in. lift Coil Springs
BST07
SoCal
So after doing some research I found these coils Skyjacker D30 Softride Coil Spring, they are for 94-01 but I was wondering if they would fit on my 07. If they don't is there any other 3 inch lift coils that would fit. thanks in advance.
B
BST07
SoCal
They were for 1500,2500,3500 94-01, I just meant the diameter of the coil being the same so it will seat properly.
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
blackbeautyhemi is asking what the specs of your truck is, not what the springs are made for. Without knowing your specs we can't tell you anything. If you have a 1500 4wd the answer is no. If you have a 1500 2wd the answer is maybe. If you have a 2500/3500 then look for coils actually meant for a 2007.
B
BST07
SoCal
I have a 07 Ram 1500 2wd
blackbeautyhemi
Lewistown, PA
Thank you brandonjansen. But yea I'm still doubting they'll fit
B
BST07
SoCal
Right on, I guess I'll go with the maxtrac 2.5 in then cause I can't seem to find any with a definite, "yes these will work" thanks for the help
Lil_Ram
Power tech 3.7L
Go to Rough country they have a 3in lift coil you have to call them and ask for it out of the kit they have.
B
BST07
SoCal
Thanks a lot, I will do that then. :favorites13:
B
BST07
SoCal
To follow up on this if anyone ever has the same question CST also makes 3 in. lift coils, the part # is CSC-D3-2.
