I currently have an 02 Dodge Ram 1500 with a 1 1/2" Daystar coil spring spacer leveling kit. I've been having major issues with my lower ball joints failing. Is this due to the coil spacer? If I was to remove the spacer and add a 4" spindle lift would the truck still ride rough or would it be more smooth?
Also, how difficult would it be to remove the coil spacer and install the spindle lift?
