6" lift brake lines
Glburacker
How do you relocate the brake lines when installing a 6" lift. I have an 07 ram 1500 quad cab 4x4 and while installing my lift ram in to a problem. The instructions say to cut strut tower and remove brake lines to pull them down 4 inches. Not sure how to do this as the instructions are not detailed enough. They do not show exactly how you do this. Plus the lines at the strut tower are hard lines. Will the be ok if they are pulled down. Any help will be appreciated.
Jerseystyle
Why not go with longer lines? Crown Performance makes some nice lines and you can custom order them for your Truck.
Sent from my SAMSUNG-SM-G890A using Tapatalk
R/T_Fire
Pleasant Grove
This is the best suggestion and way to go... yes its a little more coin but worth it.
