Custom End Links
RubberFrog
I bought these from a member on another forum a month or so ago. They were a little too short for my lift so I had to buy new 5/8 SS rod to lengthen them a bit. I finally got the rod in yesterday, cut it to the length I needed, and got them reassembled. It was a bit of a surprise this morning when I realized I had to drill out the lower control arm to accomodate the larger stud mount (thanks for the heads up...). A little cutting fluid and low rpms went right through it in a matter of minutes.
So here they are. What do you think?
ramhunter9
P-Star Jeep Wrangler
frog they are awesome man , you do good work and have a bitchen truck ...lol someone had to say your fav word .....bitchen
RubberFrog
RubberFrog
They feel tough! I wanted something more durable than the stock links, but I admit there was an appearance issue also.
ramhunter9
george , didnt know if you seen my last post on DF you your question . yes i used bushings on mine . they came with them .
ramhunter9
hear is a pic
freeze
VB, VA
5.7L HEMI
Nice links! Any idea what company makes them? The link bushings that came with my lift are cracking.
ramhunter9
mine are suspension maxx links .
RubberFrog
RubberFrog
They're from kore. I got them off a member on another forum who managed to get a set from them. I don't know if they're a production item.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Look good frog. How many hours you spend detailing the underside of your truck?
08QuadRam
Hey George. They look good on your truck. Sorry I forgot to mention that you'll need to drill out the hole on the LCA for those.
It was amazing when I had them on my 1500, just going from the OEM ones to those.. I felt the difference. I still can't get over how BIG of a rod you need! :)
RubberFrog
RubberFrog
No worries Mike. Like I told you, I have no problems drilling, cutting, or welding on my truck! As long as that rod is, I couldn't bend it when I clamped a test piece in the vice.
