Death wobble
Hunterrauchq
Hey all, we have a 2003 ram 2500 that we ordered from the factory and had lifted the day it arrived 12 years later we now have the death wobble.
What is the photographed part? Could that be the problem? Where do we go from here- the trucks unsafe to drive.
As a note the tires are recently replaced as we though the old ones may have been the issue.
Sitedrifter
Looks like a sway bar end link. That will not cause your issue but you should replace both sides with nice urethane bushings. As far as what is causing the wobble, I can't help beyond suggesting to search the forum.
H
Hunterrauchq
Is it just a guessing game?
I have searched many fourms... The answers I have got are to replaces everything.. One pieces at a time untill it is fixed there has got to be a better way?
EWC88
Southern NJ
Need to replace mine, every time I look for urethane ones I'm not finding anything. Closest I get is MOOG but the description said it could be either polyurethane, rubber, or something else depending on automobile.
Do you know any that are guaranteed urethane?
Lil_Ram
Power tech 3.7L
Poly bushings
Here's a link to some poly bushings I know people who swear by these lifted or lowered. http://www.energysuspensionparts.com/products/dodge_ram_2500_4wd_2003
Rustproofcorn
6.7 diesel
You didn't happen to have and then replace your tires with Bfg ko's did u?
