MarkV
- Nov 24, 2014
- 1,244
- 520
- Ontario, Canada
- 2003
- 4.7 Magnum V8 NOW with Moose Power
So my pinion nut had come off a while back. And so while it was in the garage i did a engine job. Long story. But i fixed the notorious tick it had. So now i move on the the second job.
The rear diff. A Chrysler 9.25. I have put all new bearings in it. Also i have put a Detroit TruTrack in. I assembled it according to the repair manual. And it all went together quite well. I took it for a ride. And i noticed a noise when i applied power. Not when coasting. I don't think when i floor it. Just coasting to power. It sounds like misaligned gears. Kinda hard to explain the sound. It will make the noise when i put it up on blocks and run the tires at 80-90km (50 mph)
Backlash is at .0009 to .0010. When i mark the gears it shows a good pattern. The adjuster cups are at 75 ftlbs.
I have another axle i bought and is in decent shape. I could swap gears out.....
Any one have any ideas??
