dirtystick
Updated Package - Thoughts/Input/Suggestions?
6 inch Crossmember/Knuckle Lift Kit with ES3000 Shocks - $1384
Same as below
Goodyear Wrangler DuraTrac LT315/70R17 - 4 X $264
Overall Diameter 34.4 Inches
XD Series Matte Black And Machined Addict - 4 X $187
17X9, 5 on 5.5 Bolt Pattern
Backspace 4.5 in
The Below is the Original Post
So after getting input from people the below is the kit I have put together to get things going. Please any feedback or suggestions is helpful as I want to do this right from the start.
Lift Height: 6 Inches
Front Lift:Spindles/Knuckles
Front/Rear Crossmembers
Compression Struts
Front Sway Bar Spacers
Bump Stop Extensions
Steering Correction: Not Needed
Extended Length Brake Lines
Rear Lift: Block/U-Bolt Kit
Shocks: Rear ES9000 Shocks
Shock Boots Not Included
Max Tire Size: 35X12.50
Wheel Size Range (Inches):18-20
Wheel Width Range (Inches):8-9
Min-Max Backspace (Inches)4.0-4.5
Goodyear Wrangler DuraTrac LT315/75R16 - 4 X $242
Overall Diameter 34.6 Inches
Rock Crawler Series 152 Gloss Black Street Lock Wheels - 4 X $127
16x8, 5 on 5.5 Bolt Pattern, Backspace= 4.25 in
Same as below
Backspace 4.5 in
Compression Struts
