front drive shaft 4x4 noise 6 inch lift
Izzyb47
Northern NJ
Mopar 4.7l
Ok so i have an 02 dodge ram (new body style) with a skyjacker 6 inch lift the lift kit is great everything is in good condition. i bought it with the lift. I immediatley had a problem with the front shaft and again when i replaced it. saw there is no transfer case reclock ring. would that be the issue??? please help
Trenton
its the steep angles on the ujoints you need to have a good drive shaft built or replace all with grease able joints and grease it lots every 1500 miles or less. A double cardian type joint would work best
Mistwalker
Pittsburgh, PA
Just a bad angle coming off transfer case with a lift. I just replaced my front shaft again and hope it lasts thru winter. Snapped half the cage out. Either reclock transfer case or get a custom shaft made.
One I'm thinking of is about 3/4 way down this page.
Dodge truck driveshafts page
m4mckeen
Any updates I have the same issue same lift with no reclock ring
