IQRaceworks
- Apr 6, 2016
- 20
- 6
- 2004
- Hemi 5.7
I've got an 04' Ram 1500 QC, and I'm wanting to crank up the front bars a little to level out the front end...probably a 1.5"-2.0" lift.
Because of the extra lift, if I keep the stock front shocks....they are going to be extending to the stops all the time, and that's not good.
I've done some searching through the forums, and I've been finding all kinds of info on front shocks with a level kit....but it's all over the place.
Some guys are saying that the stock length Bilstein shocks are what I should use.
Some guys say to use the stock oem shocks, and just add some lower mount extenders.
Some guys say that you need the locker 5100 Bilstein shocks.
Some guys are saying that you need the 5100's but need to add longer bump stops so you don't bottom out the longer than stock shocks.....I haven't really found enough of the same info out here to really trust any of it.
When I go to the Bilstein suspension page, they don't even list shocks for the 04' Dodge Ram 1500.....for some reason, most aftermarket suspension places don't either. Is the 3rd get Ram an oddity when it comes to suspension?
Any info on the prop front shocks and parts I should get would be a huge help! Thanks
