I need help... Again
Colin_5.7
I've seen a few topics similar to what I'm asking but none exactly like I need. I have a 03 1500 reg cab short bed 2wd (completely stock), and I want to be able to fit 35" tires comfortably. I don't know if I should go with a lift kit or a leveling kit, I also don't know which specific lift or leveling kit to get. And information helps thanks.
derekp
Buda, Tx
1990 5.9 Cummins
Maxtrac 7" spindle lift and you will fit them easily.
blackbeautyhemi
Lewistown, PA
Yea maxtrac or cst make good 2wd lift kits.. A 4" lift is prob the minimum you'd wanna go to clear 35's without a worry but the 7" on derekp's looks good with them as well. All in how high you want it to sit.
EWC88
Southern NJ
I have the maxtrac 4.5" spindle lift and fit 35's on my stock 20's.
C
Colin_5.7
Do you ever have any clearance issues? Do you take it offroading?
EWC88
Southern NJ
Haven't gone off-roading yet with it so not sure with that, clearance is fine...if it stops raining I'll get some pics of the truck how it sits and when I turn the wheel at full lock.
C
Colin_5.7
Ok cool, some pictures would be great, thanks!
derekp
Buda, Tx
1990 5.9 Cummins
I say go for the 7" for just a bit more. You'll probably end up wanting it in the future. EWC88 wants to go bigger now. I say just go for bigger the first time. Lol
Here's mine with the 7" and 35s. Ignore the red center caps, they're black now.
Lil_Ram
Power tech 3.7L
I believe I posted mine the last time but it was dark in that picture but here's a 7in lift on the same body style with 35s
I have no clearance issue but at full lock I do have a little rubbut I have a -36 offset if I remember right
EWC88
Southern NJ
Took forever to get pictures but here you go!
Driver side full lock:
Passenger side full lock:
Don't mind primer paint job lol
Lil_Ram
Power tech 3.7L
Those are some awfully tight gaps there EWC
EWC88
Southern NJ
The last pic was a horrible shot there's a bigger gap then that but yea still pretty close but no rub! lol
