Leveling Kit Problems
Crescent1101
Tampa, FL
3.0L ECODIESEL
So I finally get motivated to install my Hell Bent Steel Leveling Kit. I get pretty much everything apart except the lower shock mount bolt. I think the bolt is bent since I got the nut off. Any ideas on how to get this thing out? I am thinking of going to buy a heavier hammer. I think as a last resort I could cut the bottom shock mount but I really don't want to do that.
Also, should I get a OEM replacement bolt or something better quality?
caps
Tampa
2006 Thunder Road
I'd get a heavy dead blow hammer
xb1230
Hobby Mechanic
South Shore of Montreal, QC, Canada
BFH should do the trick. If you have access to a zip gun it may help free the bolt out of its position even if it is bent a little.
Not sure you need an OEM bolt, your local Auto Parts store should be able to provide a correct replacement at a much lower cost.
Good luck
usaf2006
Augusta, GA
Yours must be frozen in the bushing. Mine on drivers side was slightly bent and a 2lb rubber mallet got it out. Mine was there since factory install, 105k miles ago. Soak it in whatever you prefer, wd40 etc. For a few days, might help.
Crescent1101
Crescent1101
Tampa, FL
3.0L ECODIESEL
Thanks guys. Want is a zipgun? I'm going to power wash everything and then coat it in liquid wrench
Prospect62
Central NY
How'd the install go? Did you get it in? Results? Are you happy?
I'm looking at the same kit.
