Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > Lifted
Sponsored Ads
Register to remove these ads.
Lifted
Lift installed, picture time!!
This is a discussion on Lift installed, picture time!! within the Lifted forums, part of the 3rd Gen : 2002 - 2008 category!
Register to remove these ads. It's free! Originally Posted by ramin44s What shock did you go with? You may need ...
Reply
Old 01-26-2012, 08:41 PM   #41 (permalink)
TexasRammer's Avatar
Ram Year: 2002
Engine: 4.7
Default
Originally Posted by ramin44s View Post
What shock did you go with? You may need a longer shock
I got the Rancho 5000 that were in that link that I posted earlier
Originally Posted by Oefootball_70 View Post
Unless you want to keep replacing parts pull the spacer. It's a lot to ask from your factory set up... I would look into a spindle to run with your coils and have a 7 inch lift. But the coil and spacer is a recipe for bad luck.
Just my opinion.
To run that spacer you need aftermarket UCA and they arent cheap. It's cheaper to buy spindles and have 7 lift rather than UCA and have 4.
Eventually i might get some aftermarket UCA. If I got the spindles that would give me a lot more lift, and I would want to get a bigger block for the rear and bigger tires or else it ould look bad. And adding those up would just be to much money
__________________
TexasRammer is offline   Reply With Quote
Old 01-28-2012, 08:41 AM   #42 (permalink)
KGBIGCOUNTRY's Avatar
3rd Gen / Site Mod
Ram Year: 2004 RCSB/2005 QCSB
Engine: 5.7 / 5.7
Default
looks good
__________________
RamForum.com Moderator
Its Tweaked & Twisted
Crazy Spartan on a 112lsa Thumping It, PWR Heads Opening It Up, Coated Pacesetters Doing The Rest, Tuned by Spooldu with DSP
Powed and Tuned by King Motorsports
KGBIGCOUNTRY is online now   Reply With Quote
Old 01-28-2012, 07:24 PM   #43 (permalink)
Ram Year: 2002
Engine: 4.7
Default
Originally Posted by KGBIGCOUNTRY View Post
looks good
thanks!
__________________
Old 02-11-2012, 11:28 AM   #44 (permalink)
ramin44s's Avatar
Ram Year: 2007
Engine: 4.7 v8
Default
hows everything holding up?
ramin44s is offline   Reply With Quote
Old 02-11-2012, 12:33 PM   #45 (permalink)
Ram Year: 2002
Engine: 4.7
Default
it all seems fine, rides good. I didnt replace the boots, im probably just gonna replace all the ball joints later once it warms up. Ill probably just stick with normal control arms unless I can find some aftermarkets cheap enough.
__________________
Old 02-11-2012, 12:52 PM   #46 (permalink)
ramin44s's Avatar
Ram Year: 2007
Engine: 4.7 v8
Default
honestly man i would just wait till the balljoints wear out then worry about the boots, thats what im doing. you probably wont have to worry about them for along time. i think i may add a spacer to my CST lift and get at 8'' up front lift
Old 02-11-2012, 05:59 PM   #47 (permalink)
Ram Year: 2002
Engine: 4.7
Default
thats probably what ill wind up doing. by the time the joints wear out i might not even have this truck, something else will probably crap out
__________________
Reply
Bookmarks
Tags
2" rear lift, 4.5" front lift
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Its that time again....Turkey Rod Run time @ Daytona AlljackedupRam Member Trucks 11 11-28-2011 06:31 PM
new cst lift installed! ramin44s Lifted 39 10-06-2011 06:03 PM
6" Pro Comp Lift Installed! Musclemckeester Lifted 98 07-12-2011 11:15 AM
Expected time to install a body lift?? pullin48 Lifted 17 03-28-2011 03:38 PM
new picture RubberFrog The Lounge 42 02-07-2011 10:36 PM
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
