Lift Help!
RedRobin
I have an 07 1500 4x4 and i have a leveling kit on there with 35's now. i am wanting to put on a 3 inch body lift and then crank the torsion bars about 2 inches and put 2 inch blocks in the rear? will this lift work and look good? well it be pretty high?? if you know anyone with this set up please post pics! THANKS!!
ramhunter9
P-Star Jeep Wrangler
Body lifts and level lifts are 2 different things . One just lifts the body and the level just lifts the front . I would not recommend a level and T-bar crank as you will have more headache than its worth with stressing out OEM parts . Im not even sure you can level and crank at the same time as level lifts are keys .
IMO do it right , get a suspension lift .
Welcome to Ramforum
ramhunter9
^^^ this ... see im have forgotten everything about 1500's .. i feel dirty
