Lifted Ram aftermarket wheel/tire questions???
Danimal77
Pontiac, IL
About my truck....stock 08 1500 4x4 at the moment. Truck goes to the shop in the morning to have Bilstein 5100 Leveling struts and rear shocks installed and alignment. I have a Zone 3" body lift waiting to go on once work schedule allows. So my Ram will be 5" higher in front and 3" higher in back after everything is installed.
I was planning on running 20x10 XD wheels (Rockstar or Monster) and either Toyo or Nitto 325/60R20 A/T's.
Until today, when I saw a truck and fell in love with the wheels/tires he had. He was running 22" chrome XD Monsters and Nitto Terra Grappler A/T in 325/50R22. It was on a late model Tundra with a 3" level according to the guy. It looked SICK!!!!!!!! I thought 20's were big....22's are real big!
Anyway, once I got home I started researching.
I can get 22x9.5 chrome XD monsters that fit my bolt pattern. Offset is +18 and backspace is 5.96.
The Terra Grappler A/T's in 325/50R22 equal 34.84 dia and 12.95 wide on a 10" wide measuring rim.
Big question.....Will a 12.95 Tire on a wheel with +18os / 5.96 bs fit a 1500 with 5" of lift in front??????????
I know nothing about o/s and bs! Can anybody give me a little guidance.
Vendor
Florissant, MO
2x 5.7L & 6.2L
only thing I know is that those 22" tires are going to cost you a ****ton.
Danimal77
Danimal77
Pontiac, IL
I don't want to have to trim anything........I can't find any pics of these wheels on a Ram to see how much they stick out. I'll continue to look!
ramhunter9
P-Star Jeep Wrangler
22" are getto IMO . If you tow they wont be worth a dam . 20"s are ok .
But if its all for show and no go then 22's would be cool .
Tires ... just make sure you dont get a wide tire like a 12.50 as you will need flares or a new paint job every year .
Try to stay as close to stock rim width .. i think its 9.5 and a tire that is the same width as stock so you will save paint and will not have any rubbing .
With myself seeing your truck in person i would definitely do chrome rims , but i would stick with 20's and have some rubber to absorb the bumps . keep in mind the less rubber you have the ******* the ride will be .
Danimal77
Danimal77
Pontiac, IL
My plan all along was 20's until I saw the 22's yesterday. Nowhere near ghetto! I gotta have em....if they will fit! Rubber sidewall should be about the same as stock. I have 20's and 33's now and want 22's and 35's. Should be pretty close.
ramhunter9
like i said they will fit but you will have a smaller tire and will feel every little bump in the road .
Give up ride comfort for looks ? that is the question you must answer yourself
Danimal77
Danimal77
Pontiac, IL
I don't think it will be bad.......My truck is 2 years old with 6700 miles and has never seen a gravel road let alone off-road. I just don't want rubbing problems.
ramhunter9
only way you will rub is on a wide tire like a 12.50 . but like i said if you go that wide you will have more issuse than rubbing, your tiers will stick out past the fender wells and **** up your paint . A 35x11.5-22 will tuck in nicely . to be safe a 35x11-22 will be perfect that will sit in the fender close to stock .
ramhunter9
best thing to do is go to a tire shop and have them put one on the front and turn to full lock to find possible rubbing .
Danimal77
Danimal77
Pontiac, IL
I have 2" bushwacker flares , so I'm not worried about fukken up my paint. The tires are A/T and 12.95 wide. Wheel is 9.5" wide with a +18os and 5.96 bs. Rubbing is my only worry!
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
20s dude
ramhunter9
oh **** ... 12.95 wide tire is not safe on a 9.5 rim .... you will pop of the rim ..tire is to wide . I did not see the size earlier .. you need at least a 10.5 wide rim .
Buddy of mine put a 13 wide tire on a 9.5 rim and went on a off ramp curve and the tire popped off the rim and he wrecked his truck . And to boot insurance would not pay for it .
