MOOG vs. MEVOTECH
EWC88
Southern NJ
Need to replace my sway bar end links and the bushings. I've seen on ROCKAUTO several brands but the two I heard the best are MOOG and MEVOTECH. I have used MOOG before because of their quality, but was curious how is MEVOTECH to MOOG?
usaf2006
Augusta, GA
Just bought my Mevotech sway bar end links from rock auto a few weeks ago. Fit great, greaseable and cheap! Had then on for about 200 miles. Feel good with no issues. I also put new sway bar bushings too. Went with Moog on those since they were cheap. $10 for two if I remember.
E
EWC88
Southern NJ
Yea I was looking at going with MOOG bushings. I am a 2wd so this is for obviously my front, would this be the right one (info taking from ROCKAUTO): MOOG K7352. Front To Frame; Includes Split Design For Easier Installation; 30mm Sway Bar Diameter
I am no sure what size my sway bar is.
xtremewlr
Tucson, AZ
I've read good and bad about Mevotech stuff. The suspension shop that I am taking my truck to to have the front suspension rebuilt and the truck lowered highly recommended the Mevotech parts. They do a lot of suspension work so I am pretty confident in trusting their judgement on what parts work and don't work.
Moog has always been good but you can also find people that have had issues with Moog parts before.
My 04 QC Hemi Ram has the 34mm front sway bar. Not sure if Dodge used a different size based on year or what motor was used or based on trim.
E
EWC88
Southern NJ
Yea I'll have to see if work has some type of tool to measure the bar because mine is a 02 4.7 motor
usaf2006
Augusta, GA
That sounds right, took me two weeks to figure out what size mine was, and I can't remember what it was. My 4wd bar is either 34 or 36.
Lil_Ram
Power tech 3.7L
If your still curious about if it fits foot federalmogul.com you can look at it there but I'd go with mevotech moog your paying to much for the name trust me
Joe.G
2004 SLT Quad Cab Short Bed
I ordered Energy suspension sway bar bushings for my 04 1500 quad cab 4wd hemi, The 4wd bushing were a touch to big and I had to order the 2wd set which are 2mm smaller then the 4wd ones.
