glram04
- Apr 9, 2013
- 7
- 9
- 2004
- hemi 5.7
Not sure which forum to put this in which I will explain as I explain what is done to the truck and will be done.
Current set up is a 2004 ram 1500 6 inch bds non torsion drop lift, 3 inch body lift and pre runner fenders running 38/13.5/17 tires, being pushed by a 5.7 hemi with header back exhaust, diablo sport tuner 93 octane set up, procharger 6-7 psi, 4.56 gears, 545rfe auto transmission.
The problem is I keep breaking stuff with my half ton ifs front diff, sheered front drive shaft, cv axle came off diff (not even at an extreme while sitting just lots of travel), and one time I hit rutt and ended up breaking almost everything on front drivers side (spindle, lower control arm, sway bar link).
So what I am doing to fix this is putting my chassis on a 2004 dodge ram 2500 dodge ram frame, eliminate body life and do either 6" or 8" coil over shock lift, and looking at running 38.5/14.5/16 wheels maxxis creepy crawler which with a 12 inch rim says will be 38.8 diameter.
I am going to make that frame and suspension work with 1994 4x4 dually axles dana 60, and dana 80 with trusses, for strength as well as the option of lower gearing. My 4.56 with 38's set ups currently is under powered at low rpm I constantly run tow haul to keep from going below 1500 because it feels gutless until about 1900-2000 rpm anyway. So I am split between 5.13 and 5.38 gears I don't do much highway but I did look into that it says with overdrive at highway speed 110 km/h(max speed of tires is 120) 5.13 would be 2034, 5.38 would be 2134 so neither is horrible. What would you suggest I run?
