Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > Lifted
Lifted
Post pics of your 6" & 8" lifted 1500s
This is a discussion on Post pics of your 6" & 8" lifted 1500s within the Lifted forums, part of the 3rd Gen : 2002 - 2008 category!
Show off your 6" and 8" lifted 1500s, preferably with 2"-3" body lifts. List the wheel and tire specs too. ...
Like Tree29Likes
Reply
Old 08-06-2016, 12:43 PM   #1 (permalink)
Banned
Ram Year: 2003
Engine: 5.7 hemi
Default Post pics of your 6" & 8" lifted 1500s
Show off your 6" and 8" lifted 1500s, preferably with 2"-3" body lifts. List the wheel and tire specs too. Trying to get an idea of what my truck would look like before I pull the trigger.
Sponsored Ad
Register to remove this ad.
Hemipig is offline   Reply With Quote
Old 08-07-2016, 05:54 PM   #2 (permalink)
Ram Year: 2007
Engine: Hemi 5.7
Default
No body lift. 4 inch zone lift kit, with rancho my ride quick lift struts for a total of 6in front 4 in rear. 20 inch moto metal rims 10in wide with -24 offset. 35x12.50 federal couragia Mt tires. I have a few more pics if you want just let me know.
White12bighorn likes this.
Jwrobson84 is offline   Reply With Quote
Old 08-07-2016, 09:45 PM   #3 (permalink)
blackbeautyhemi's Avatar
Ram Year: 2006
Engine: 5.7 HEMI
Default
6" rcx with 35's. Need to bump my bilsteins up to .7" setting from zero cause I still have a little rake yet.
R.L.K. likes this.
__________________
*December 2014 TOTM Winner* 6" RCX, Bilstein 5100's, 35" Toyo open country mt, 18" Fuel Kranks, LSD 3.92 gears, SRT hood scoop, 20% tinted windows/drop tint, K&N CAI, throttle body spacer, Diablosport w/ hemifever 93 tune, 180* stat, true dual cherrybomb extremes w/ x pipe, high flow cats, black headlights, LED tail lights/3rd brake light, rhino liner, tri-fold tonneau cover
blackbeautyhemi is offline   Reply With Quote
Old 08-08-2016, 11:42 AM   #4 (permalink)
Banned
Ram Year: 2003
Engine: 5.7 hemi
Default
Blackbeauty how much was your lift? Where'd you get it? Are you 4x4?
I'm not having an easy time finding a 6" lift for around 1000. Can't swallow spending 2k+ on a fabtech or skyjacker when the install at my local truck place is 1000
Old 08-08-2016, 09:55 PM   #5 (permalink)
Ram Year: 2006
Engine: 5.7 HEMI
Default
Ordered it straight from rough country. I think it was $1100. Mines 4x4 but 06 and up have a different front suspension than yours. That's why the sizes are different from mine to yours.
__________________
Old 08-08-2016, 10:41 PM   #6 (permalink)
Banned
Ram Year: 2003
Engine: 5.7 hemi
Default
So your 06 has a 6" 4x4 kit available? It only shows a 5" for mine. 3 inch rear and 5 inch front
Old 08-09-2016, 11:58 AM   #7 (permalink)
Ram Year: 2006
Engine: 5.7 HEMI
Default
Yea mines 6" front and 4" rear. Not sure why it's only 5" for yours.
__________________
Old 08-09-2016, 07:14 PM   #8 (permalink)
Banned
Ram Year: 2003
Engine: 5.7 hemi
Default
After hours and hours of research, I have pretty much come to the conclusion that getting a 1000, 2000+ dollar lift for a 1500 is pretty pointless because of the independent front suspension.
The 2500 and 3500 would actually get an upgraded coilover, which would help you in an off road situation. The Independent front suspension pretty well screws us 1500 owners, and makes our lifts cosmetic and very unsuited for legit offroading.
The only thing that lifts our trucks with these seemingly fancy kits are extended knuckles in the front and blocks that go in between the leafs in the rear.
That's a BS ripoff. If your truck is a 2wd, you put 3" spring spacers in the front, 2" blocks in the rear leafs, get a 3" body lift, and call it a day. If you have a 4x4, get 2" blocks in the rear leafs, crank the keys in the front to even it up with the rear, get a 3" body lift, and you're good.
If your only goal is better cosmetics, this is the way to go. Because even the "suspension lift" is only cosmetic really.
Both of these methods appear the exact same as a 6" suspension lift on other trucks. You can easily fit a 35" tire if not a 37".
This method of spacing/cranking the front and blocking the rear, and the body lift, all costs less than 800 bucks parts and labor installed at a shop. That's a lot different than the 1250 for the cheapest kit like rough country and 2000 for the intermediate kits like bds, skyjacker and procomp, then the 1000 dollars at a qualified shop to install it.
It's actually pretty ridiculous. I can understand if money isn't an issue, then yea get the rc/bds lift and the body lift as well and get even higher. But for the money, it's hard to argue with the alternate method for less than 800 installed.
Old 08-14-2016, 09:50 PM   #9 (permalink)
triple111's Avatar
Ram Year: 2002
Engine: 4.7
Default
Hemi I like the concept of that. However, I've heard that your cranking your key basically tops out the shock even just trying to level the front from a stock height. Also how much would this fuck up your CV axles?
triple111 is offline   Reply With Quote
Old 08-15-2016, 07:26 PM   #10 (permalink)
Ram Year: 2005
Engine: 4.7
Default
Hemipig, thanks for spelling that out. I am one looking for lift, but no real off roading plans. In addition to the longer knuckles, my front diff needs to be lowered because my shaft angles are I steep as I want them.
cityboy1987 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
4" or 6" lift with 35" tires pics plz Lone_Wolf Lifted 89 11-26-2015 07:37 AM
Looking for pics of 6" suspension lift, 3" body lift on 35" tires Thatdude596 Lifted 13 01-27-2015 06:45 AM
Post deployment mods... "Flickr Pics link added" slickram Member Trucks 3 01-01-2014 08:08 AM
What mods do you have waiting to get installed? "Post Pics" johnnysart General Discussions 3 08-23-2013 03:29 PM
Pics of a lifted Ram with 22" or 24" wheels and tires? toddy204 Lifted 9 02-17-2012 07:24 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
