shocks
Marx
Southeastern Ontario Canada
Hemi 5.7L, 345 ci MDS
I have a 05 1500 4x4 and i'm leveling my truck this month (only needs 1 1/2") and i want to get the bilstein shocks, now i contacted bilstein and they said the HD's will work but i may need extensions, is there a model number anyone is using that do not need shock extensions?
this is the shock Heavy Duty Series Front (BE5-6928-H2)
johnnysart
Albuquerque
5.9 Magnum
Just get longer shocks for the front, that what I did.
Marx
Marx
thats what i want i just don't know what length to get, do i just add 2" to the over all length? or do i need to know the travel length?
Deviate
St. Augustine, FL
2005 4x2
I'm 4x2 but what I did was buy shocks for the 2500. They are the same shock as a 1500 just 2 inches longer. At least that's the way it worked for the 4x2.
ramhunter9
P-Star Jeep Wrangler
i have shocks in my garage that came off my 2500 i think they have 50k on them .
johnnysart
Albuquerque
5.9 Magnum
I just told Bob when I bought mine that wanted the longer one's and he ordered them for me.
Marx
Marx
i'd like to run a bilstein but every where i call says no for an 05 4x4
should i just get the Rancho RS5000?
johnnysart
Albuquerque
5.9 Magnum
I tried looking through some of my old reciets but could not find it.
johnnysart
Albuquerque
5.9 Magnum
Simon, I email one of the guys from dt so I'm waiting for him to join up or pm me so hopefully I'll be able to let you know.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Simon sorry for not seeing this sooner I can post up all the part numbers you will need to get the Bilsten shocks I have on my truck. I spent the extra 10 per shock for the brushed alum ones and you will have to get new rubber eyelets for em. I bought all of mine from Shockwarehouse.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
If your doing all 4 and thats what I would suggest after seeing my stock shocks after 55k you will need part numbers and amouts to fallow:
2)F4-BE5-6248-H5.... These are Bilstein 5100 offroad racing units
2)F4-BE5-6243-H5.... These are Bilstein 5100 offroad racing units
6)98108G.... These are Bilstein bushing 3/4 urethane eyelet
6)423730.... These are Bilstein sleeve 20x14.4x42.4
These is the setup I have on my truck and the ride quality is awesome. These shocks are for a diff truck hence the need to change they eyelets and sleeves but with a shop vice and a drop of oil they switch out easy. If you havent bought the keys yet you could just jack the front of your truck up and tighten your t-bars about 5-6 cranks and get the 2inches and save the 70-100 bucks. When I did these shocks I had Skyjacker 2" keys. Any more questions just post em up.
Marx
Marx
thanks man,
i'm actually living in a condo so no shop/tools for me, i think i'm gonna get the tire and shock place to do it, i hate spending money on stuff i know i can do my self.
Marx
Marx
Which ones are the front? might hold off on the backs for a bit
also i might put a 1" block in the back will they still work?
i just searched these numbers at the Canadian dealer site do they look right?
Essex Distributors
Essex Distributors
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
You can do all of it in a yard with about 4 tools even if your putting on the keys, I will check on that sight but if there the same numbers or list as the cross just blue and yellow then they are prob right. The ones I got just make the bottom of the truck look cooler.
