Orange08ram
- Dec 15, 2015
- 36
- 21
- 2007
- Hemi 5.7
Ok so last weekend I put on the hell bent steel leveling kit 2.5inch. And after I few days I started getting a light clunking on the driver side and gets worse every day. Took the whole front end back apart checked everything re torqued everything to spec. And replaced tie rod ends and ball
Joint and axle cause the cv boot was busted. And also took the sway bar off to see if the sounds was coming from there and no. But after all that I am still getting the clunking. Can someone help me out here. Maybe someone has had this problem before
Truck is a 2008 1500 4wd
