cr500
I installed a leveling kit on my 2002 dodge ram 1500. I have 3 1/2” of total front lift. Then put 2” blocks in the rear. I looking to get a 6” lift kit from skyjack and run 37” tires. I would really like to get 40s under it. I’m running 35” tires with the new keys and blocks installed. Before I start this project I was thinking about getting away from the independent front suspension and going with a solid axle. I already had to replace the right side CV drive axles and intermediate shaft when I got this truck. I’m looking to set this truck up the right way! Is this a complete fabrication job or is there someone that makes aftermarket parts to do this? should i go with a solid axle before i lift it?
