FancyStancy
I have a 10" lift on my truck. I bought the truck with the lift. After buying the truck I removed all of the lift to have everything painted. When I put everything back together I didn't like the way the truck still was on factory sway bar end links (Whoever did the lift bent the links so they would not hit the coils). This really bothered me because I knew it wasn't correct or effective. I have been going without a sway bar and am ready to order the end links. When I put factory sized (non bent) end links on, the sway bar hits the coil. I do have a sway bar drop bracket but i'm pretty sure that I will need much longer end links. Is anyone running a 10" lift or bigger that has some good opinions on end links. I have seen ones online but they always say they can fit up to a 6" lift...
