Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > Lifted
Sponsored Ads
Register to remove these ads.
Lifted
torsion keys stock or new?
This is a discussion on torsion keys stock or new? within the Lifted forums, part of the 3rd Gen : 2002 - 2008 category!
Register to remove these ads. It's free! OK so i'm new to the forum thing. I'm wondering if it is ...
Reply
Old 02-06-2012, 09:56 PM   #1 (permalink)
Ram Year: 2004
Engine: 4.7
Default torsion keys stock or new?
OK so i'm new to the forum thing. I'm wondering if it is worth buying the leveling kit or just crank the factory bars. I'm wanting to run 285/70/17 some sort of m/t thinking the fierce attitudes. any suggestions?
Jethros04Ram is offline   Reply With Quote
Old 02-06-2012, 10:32 PM   #2 (permalink)
03MopaRamman's Avatar
Ram Year: 2003 Forgottens
Engine: Hemi 5.7 (1 of 2)
Default
Thats the size Tires I run but with Ready-Lift Keys as I have Gator Mud-Flaps too.
Not sure without keys if it would rub? IMO a non-leveled 1500 has too much Rake and looks outta place anyways. Not a Fan of Cranking the stock Keys but thats just me.
I also ran 305/65/17's which are about same height but wider.
BTW: Welcome and stick around you'll enjoy your stay here.
__________________
6.1 Cam/Springs/Rods/Oil pump-SC3865-85 mm Ported TB W/Grnd-K&N-Pwr Wire-E-Fan-Hooker Headers-Flo Tech Y Pipe-Magnaflow 18" Dumped-B&M Shifter-TCI 2600 TC-Transgo HD w/Resist-TMR Delete-HD Cooler-Auburn LSD 4.56's-Mopar Cover- Modest 3" Lift-SRT Hood-RF Tactical Grille-Blk Lights-Cab Lights-OEM Hella Fogs- PWR WGN Flares-Black Bed Caps-Rails & Mopar 4" Step Tubes w/5x Amber-1OAK Steel Rims/285 Duratracs-Gator Mudflaps-Rolling Tonneau-Leather. Next:Hellwig-35's.
03MopaRamman is offline   Reply With Quote
Old 02-06-2012, 10:37 PM   #3 (permalink)
Stangshcky12's Avatar
Ram Year: 2005
Engine: 5.9 Cummins
Default
Crank the factory bars. Those tres aren't much bigger then stock so you might be able to fit them stock
Cranking achieves lift the same way keys do, keys just allow you more room for adjustment
__________________
2005 Ram 2500 5.9 Cummins 6 speed
More Here
I blame spelling mistakes on my phone and I'm sticking to it!
Stangshcky12 is offline   Reply With Quote
Old 02-06-2012, 10:41 PM   #4 (permalink)
bigbadram1500's Avatar
3rd Gen / Site Mod
Ram Year: 2008
Engine: Hemi 5.7
Send a message via Yahoo to bigbadram1500
Default
Welcome to the forum. I cranked the torsions on my 05 about half an inch from the max and even with an alignment, the tires wore unevenly, and it wasn't completely leveled. I would recommend the keys. Shouldn't have problems running 285's. I run the same on my 05 with the torsions dropped down.
__________________
RamForum.com Moderator
2008 Ram 1500 QC SB 4x4 Hemi in Sunburst Orange
SC3815, BFI, Power Wire, 2.5" Ready Lift Leveling Kit, 34" Nitto TG's, 8k Bi-Xenon Direct Fit Projectors, 6k Fogs, LED Tails, 6k Hellas behind the grill, BakFlip G2, BedRug, Wheel Well Liners, Debadged, Flowmaster 40 Exhaust, Kicker 12" CVR in Custom Console, Kicker 400.1 amp, OEM Tow Mirrors
bigbadram1500 is offline   Reply With Quote
Old 02-07-2012, 12:17 AM   #5 (permalink)
Ram Year: 2007
Engine: CTD
Default
Crank the stock keys and save the money. I wouldn't crank the torsion bars more than 2" and the stock keys will achieve that.
Aftermarket keys are just indexed a few degree's so you can crank the bars further, IMO they are a waste of money. The more you crank the bars the stiffer the ride gets, so level the truck out and call it a day...2" is plenty.
I rate aftermarket keys up there with T/B spacers and the turbonator, just slightly higher because they do allow you to crank the bars further.
Oh and it's not true that you will keep the factory ride quality with aftermarket keys to level your truck (leveled out).
__________________
2007.5 6.7L Ram CTD | H&S Mini Maxx | 4" turbo back exhaust | EGR valve fell off | 20x9 Incubus nemisis w/33x12.5x20 Federal M/T | 2" HBS level
NWRQC is offline   Reply With Quote
Old 02-07-2012, 01:04 AM   #6 (permalink)
ol'red02's Avatar
Ram Year: 2002
Engine: 4.7
Default
Save your money and crank the keys, measure like crazy, and get an alignment
__________________
ol'red02 is offline   Reply With Quote
Old 02-07-2012, 02:49 AM   #7 (permalink)
Ram Year: 2005
Engine: 5.9 Cummins
Default
Keys and cranking increase the height te same exact way, by increasing the tension in the torsion bar.
The key just acts like a shim between the adjuster bolt And torsion bar
If you have uneven wear when you crank them you'll have it when you use keys as well
__________________
More Here
Old 02-07-2012, 03:50 AM   #8 (permalink)
smiley3303's Avatar
Ram Year: 2009 Ram 1500 Laramie Crew
Engine: Hemi 5.7L
Default
Had factory ones cranked on 05 Durango enough to fit 31's then aligned no problems.
$miley
__________________
smiley3303 is offline   Reply With Quote
Old 02-07-2012, 07:26 AM   #9 (permalink)
KGBIGCOUNTRY's Avatar
3rd Gen / Site Mod
Ram Year: 2004 RCSB/2005 QCSB
Engine: 5.7 / 5.7
Default
Welcome, they have you covered we also have a how to here:
http://www.ramforum.com/f76/leveling-02-05-4x4-9788/
__________________
Its Tweaked & Twisted
Crazy Spartan on a 112lsa Thumping It, PWR Heads Opening It Up, Coated Pacesetters Doing The Rest, Tuned by Spooldu with DSP
Powed and Tuned by King Motorsports
KGBIGCOUNTRY is online now   Reply With Quote
Old 02-07-2012, 07:30 AM   #10 (permalink)
quietpeen's Avatar
4th Gen / Site Mod
Ram Year: 2011 1500 Sport Quad Cab 4x4
Engine: Hemi 5.7
Send a message via AIM to quietpeen Send a message via Yahoo to quietpeen
Default
welcome, i agree to just crank the stock keys. If you are looking to crank them because you think you need to so those tires will fit...............no need - those tires will fit at stock height. I personally would crank them to get rid of the huge factor rake
__________________
quietpeen is online now   Reply With Quote
Reply
Bookmarks
Tags
cranking torsion bars, torsion keys
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
stock air box 98sporttj For Sale 0 01-24-2012 08:23 AM
keys and block BAMA BOY Lifted 22 12-12-2011 07:09 PM
how lowered front with torsion bar? Kaven Lowered 10 11-15-2011 01:37 PM
is this stock KeysRam Lifted 20 06-05-2011 09:20 PM
Torsion keys badfish888 Lifted 17 09-30-2010 07:35 PM
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
