MDNUSA
Ok guys, here's the deal. Trying to install a 2" spacer in the front. Got everything torn apart smoothly until I hit the lower strut bolt. Nut came off ok but the bolt seems seized. I can turn the bolt about 3/4 of a turn each way but no other movement. I'm working in my driveway, with no air tools, and its 15 degrees outside so I didn't screw with it a ton. I plan to work it some more tomorrow but my main question is this. The tires I want, 275/65R20, are only on sale untill Saturday. If need be, can I put it all back together and run those tires completely stock for a weeks untill I have more time and access to air tools?? Thanks for the help!!!
2008 Ram Laramie 4x4 5.7L
