2002 Standar Cab. door swap to 2004
gonzalocimma
2002 Ram 1500 Std. Cab.
Hi, I have a 2002 dodge ram 1500 standard cab. new model, I need replace front door,
question: my door is round corner, I can replace with 2004 model
thanks.
HemiLonestar
MD
Doors are all the same, but not sure what you mean by "my door is round corner"?
G
gonzalocimma
ram door
the blue is round in bottom of window right side model 2002 and 2003
the green is crew cab, but is for example
Ceri
Based on those two shapes I'd say no. Looks like the lower edge has a different body line than the 02s that I'd never noticed before. I knew the window was different, but the full door shape looks different too.
ST-8
You sure that green door is not from a quad cab?
Edit just seen that. 02-08 doors are the same but obviously the cabs will make a difference about the doors
HemiLonestar
MD
All the doors are identical between reg cabs and quad cabs 02-08.
derekp
Buda, Tx
1990 5.9 Cummins
Actually they arent. The regular cab doors are wider than the quad cab doors in every year of the 3rd gens.
HemiLonestar
MD
No **** kid lol...you misunderstand. All the doors are identical reg cab to reg cab, quad cab to quad cab those years. There always has to be one lol...
derekp
Buda, Tx
1990 5.9 Cummins
Read what you wrote orginally...just cause you're older doesn't mean that you're smarter...
Gary's Hemi
Walker, La
^^^^ There always has to be one. ^^^^ Actually they still arent identical in the reg cabs throughout those yrs. The 02-03 reg cabs had a round edge on the lower back of the window & the 04-08 had a square edge. Notice in the 1st post how his window edge is round. He wants to go to a 04 & up door w/ the square edge. Here is my old 04 reg cab below. Notice how the lower back of the window is squared off. That is the op's question. To answer the question, yes the 04 & up REG CAB doors will fit on the 02-03. It is just how the door was molded around the lower back of the window that was different. The green door in the op's pic IS an 04 & up quad cab door. Here is a comparison of his 02 door to my old 04 door.
