35x12.5f20 nitto trail grapplers on a leveled 08
quietpeen
2021 TRX
Hellcat
glad they work with not too much trimming
jethro 03
jethro 03
Jersey
I'll get more pictures when I have more time and get her cleaned up and such.
Sent from my SM-G935T using Tapatalk
jethro 03
jethro 03
Jersey
Alright, here's a couple quick pictures from work. It's still dirty though. 8228c30ba9ce7edc9d373bcf3388f5a4.jpg0c3b1caa59c509b74e5cc91786e4dc26.jpg92b1600137b040521a0f157c78332a29.jpg
I'm in the market for new wheels now. I'm not sure on 20x9 or 20x10. I like the deeper lip, but I'm afraid the tires will look too thin on a 10".
Any idea on what backpacking on a 10"? If I go 9", I'll do -12, since that's technically where I'm at now with the 1.25"spacers.
quietpeen
2021 TRX
Hellcat
if you get 20x10's to have the bigger lip that would mean getting -24 mm offset. You will having rubbing issues when turning because the wheel will stick out an inch further
jethro 03
jethro 03
Jersey
I already trimmed quite a bit of the plastic to fit the tires now. But if it's going to be a major problem, I'll just stick with the 9".
blackbeautyhemi
Lewistown, PA
Yea I think you'll be looking at metal trimming with the 20x10's not just plastic liner
Hemi 5.7L V8
So I bought a new set of 295/65 20 copper stt pros. I definitely had some trimming to do, but it was all plastic liner, with just a little of the metal behind it to be sure. Some of the front side of the liner as well, but not as much.
They're at 40 psi and the ride feels pretty much the same, with the obvious exception of the whine(not bad at all) and you can feel the knobbies on the tires. It does handle better with the wider stance.
Do you mind snapping a pic of your trimming? I am rubbing slightly and I'm not sure if I have to get into the metal or not yet
usaf2006
Augusta, GA
Anyone know if 35/12.50R17s would fit better on 17x9s with 0 or -12 offset?
I'm assuming, since the rim diameter doesn't matter, that they would rub minimally with -12.
Nvm, just found a sweet thread with exactly what I was looking for lol.
