Any way these will fit?
jethro 03
Jersey
I know this is a beat to death question, but I've been looking a long time and can't find an answer.
I found a set of wheels and tires that are exactly what I'm looking for, used.
Ok, I have a 2008 ram 1500 quad cab big horn 4wd. It is leveled. The wheels are 20 x 10 -25 offset with 295/60 20 copper muds.
I'm worried that they'll rub more than I can trim. And yes, I know they'll stick out quite a bit. If anyone has any pictures, that would be great as well.
Sent from my SM-G935T using Tapatalk
e_hartzell17
They won't stick out as much as you think I have a 2001 with -24 and they barely stick out yours will stick out maybe 3" or less and they might not even run at all
e_hartzell17
I'll have a better pic soon
jethro 03
jethro 03
Jersey
Thanks for the reply. I'm leaning towards getting them. I have looked online a lot and seen a few with the same sizes that fit. Most even say with no rub, but who knows
e_hartzell17
You'll be fine they'll work fine with literally little to no run at all if any
jethro 03
jethro 03
Jersey
I actually like them sticking out. And I don't mind trimming at all if need be, just don't want to rip my fender off or not get them to fit at all.
e_hartzell17
I know the feeling with style come sacrifice lol -24 will be perfect
jethro 03
jethro 03
Jersey
I'm pulling the trigger on em, but have to wait for the guy to get his new set in. More time to contemplate I guess lol.
Thanks for the replies and the pic. I'll post what happens in a couple weeks when I get them.
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
You can definitely make them fit. It will require trimming but it will work.
PdPuNOme
Jersey
I have srt10 22x10 -24 offset rims with 305/45/22 at's and I can say I ended up putting 1" bora wheel spacers on, as the rim itself due to 22" was 1/4" from suspension, ran like that for a year but was always uneasy about the clearance. With 20" then the tire would be rubbing the suspension with same specs.
jethro 03
jethro 03
Jersey
Ok, so the guy flaked on the wheels and tires. Actually he said his new wheels were back ordered for at least a month. Maybe, maybe not.
But I found some 18x10 -24 with 305x65 (33x12.5). What are the chances I can get them to fit?
Was going to stick with stock wheels, but I can't find any tires I like that are the size I want.
brandonjansen
They'll fit no problem.
quietpeen
2021 TRX
Hellcat
They should fit, but if you get slight rubbing just crank your torsion bars a little bit.
Edit..... forget that just saw you are a 2008 leveled
e_hartzell17
They will fit no running at all 33s will fit fine it's anything bigger
jethro 03
jethro 03
Jersey
I have an 08. Haven't changed my profile lol.
I don't mind trimming the plastic liner if need be (if even needed).
quietpeen
2021 TRX
Hellcat
Saw that after I posted and edited my post lol
jethro 03
jethro 03
Jersey
No biggie, it's my fault for slacking. I'm always on tapatalk on my phone and I can't change it through here. At least I haven't found it lol
jethro 03
jethro 03
Jersey
@ E_hartzell17, I was more worried about rubbing the upper control arm. 06 and up have more of a width issue because of this. Anything over a 285 width rubs the upper arm (or sway bar).
2023RamWarlock
