back up lights
LoadedLaramie
Columbus, IN
this is about the best shot i have of them. 100w bulbs. im planning on relocating them but have yet to figure out where or when ill do it.
Mega-Hemi
US AIR FORCE '08-'18
Back in New York!
Its the ****!
And..........honestly - I'm surprised my coworkers haven't swiped it yet. LOL
It was the first mod I did to the 2010 too, and about the only thing that transferred to it from the 08.
That thing is awesome, where can someone find one??
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
I bought mine at Cabelas. I have seen them at Walgreens, Target, Lowes.....hell - lots of places. Its made by Blazer - Light Buster. That should help you find a buttload of 'em!
matt99
Shreveport, LA
What about the warm up time on the HIDs...and the quick power up/down when you throw it past reverse into drive
I know not letting them warm up and cutting the power is bad for the bulbs
OlDirtyJohn
Naha-shi, Okinawa, Japan
2004 Quad Cab 2500 *Sold*
im curious about the hids as well. what size bulbs did you use? did you have to modify the housing at all to fit them?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
If I remember correctly, they are H13s and they fit right in the hole. :D
Marx
Southeastern Ontario Canada
Hemi 5.7L, 345 ci MDS
i decided to go the LED route i've got the led light bar led reverse bulbs and led cargo bulbs heres a pic
i'll try to get a pov shot later
Marx
just snaped a pic of that i see the house is about 15ft (and is a bit under construction lol) its actually alot brighter my camera has a hard time with led light also i;m in the country so it pitch black out
HKkid
Missouri
Those HIDs rock!!! I'll probably just buy some fog lights.
AParrette
St Augustine, FL
1997 Pontiac Grand Prix
3.8L SUPERCHARGED
oh ya, havent been on in a while. ya h13. you have to trim the bulb tabs and silicone the bulb good. and since the hid bulbs can be gotten for 20 a pair. and you can buy time delayed relays so there isnt any quick bursts. and the full burn time is the same as the headlights, 1 - 5 seconds depending on outside temp
SilentRamAD
Cypress, CA
08 QCSB 2wd
287 4.7L
Well after tonight I should be looking at a set up similar to CB's under the rear leaf springs. Was rather interesting trying to figure out how to mount them but with some left over bracket metal from the E-Fan (teach's method) and a few coats of paint to prevent rusting, I figured a way.
Can't wait. I almost want to aim them a bit upwards to may be do a quick flash to tailgaters but only during the day/evening time because I'd assume at night time if it caused an accident, my ass is screwed.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
they have to prove it first..........
My first car - the backup lights didn't work. So my dad wired in a switch for them. LOL, I used it a LOT......
SilentRamAD
Cypress, CA
08 QCSB 2wd
287 4.7L
Just bein a good boy and saying in public view I'll "only" use them during the day/evening time :naughty: What can I say I dislike tailgaters when I'm doing the speed limit or higher especially when the next lanes open.
Paints dried, be back later after dark with some shots.
RamStrat
Banned
Palm Harbor, FL
Magnum 4.7
Rear: 2 - 4" 3200 Lumen 4-LED Spot/Flood lights mounted under rear bumper to each side of tow package hooked into reverse lights.
You can see them mounted under the bumber on the sides of my towing package.
Reverse Off:
Reverse On:
