badblackram06
Beauty Job, looks Great ! I am curious though, where the Handles removed or masked off in place?
I removed them. It was way easier to do it this way. The door panel has only 4 screws (philips head) and you have to unbolt the door handle (10mm)and pop out and unplug the window switches. the door panel will just pull up and off. The outside door handle is only held in with 2 10mm nuts. After they are off you can take off the plastic rod clips, that open the door, from the outside.
