Experience with Spyder 5030078 headlights...
Demon-HeMi
Houston
2003, 2003, 2008, & 2013
(2) 5.7 HEMI, 3.7, & 3.6
You use them HID's, huh. I don't think I'm quite ready to take the dive on trying them so, I'll just make up my mind on either the regular ole Silverstar Ultras or Sylvania's new ones, the Silverstar ZXE's that Sylvania claims to be the best at rivaling full-on HID bulbs. They ain't cheap, 'bout 60 bucks a pair. Lol.
Yeah, that's what I figured, they wanna sell their products as complete, "plug and play" units but they don't wanna increase their cost of manufacturing with anything other than the cheapest of the cheap headlight bulbs.
Yeah, I'll be sure to verify with a test light to make sure that the black wire is in fact chassis ground and the blue wire is the power wire.
you cant beat a HID in a projector for lighting lol
if you get the CCFL ones, make sure you get it right the first time, the CCFL controller isnt forgiving to being hooked up backwards, it will blow and not work at all and then you are left without halos on that light and having to buy a new inverter
corneileous
corneileous
Podunkyville, OK
2018 Ram 1500 Limited 4X4
Wana see something funny, i did a halogen test from cheap ebay bulbs to basic oem ones, check this out
This is a standard 4th gen headlight beam with your standard issue oem bulb
Here is your cheap ebay halogen bulb in the same headlight, and yes its installed correctly, so when people say aftermarket lights suck with "upgraded" bulbs, this is probably what they did, the probably got on ebay and found some halogen bulbs that have a very misleading label.
Yeah, I'm gettin to be really leary of buyin **** on eBay especially after my mom found out the hard way that she had bought a phony Samsung SD card for her S5 when it started causing problems and messing up her pictures. Lol. I convinced her to buy a new card from Walmart and even showed her that there were visible labeling differences on each card that made her old one look like a fake and her new one look a whole lot more quality made.
corneileous
corneileous
Podunkyville, OK
I'll try them someday...[emoji41]
Even in factory lighting, I've always been happy with the Silverstar Ultras and even the regular ole Silverstars I used to run. The only thing I wasn't crazy about with them was that they don't last for **** cuz they burn out quicker.....lol.
Don't wanna do that...
corneileous
corneileous
Podunkyville, OK
Well, I decided to go all out since I was buyin' headlights so, I decided to take the plunge and get new taillights and a third brake light to make it all match. Primarily to get rid of them wannabe Chibby-lookin' taillights they put on the 07's and 08's...lol.
Thanks for all the help, fellers.
pavementprincess
South Florida
4.7 L Magnum
How did everything work out so far? I'm looking at buying Anzo headlights (810169022863) or (846959036550)? I'm mainly concerned about night visibility????
ML Jackson
Arkansas
These are the best plug and play projectors you can get, they adjust easy and work pretty well, and when i say they adjust easy i mean just like OEM, no removing the light, turning a screw hoping its the right amount
They come in chrome and black, also have the option for LED or CCFL halos, CCFL obviously being brighter.
The CCFL ones cost around $200 and the LED ones cost around $150
Here is the brightness comparison
I personally like the way they look at night, in my opinion with the fit and function of them are could be mistake for an OEM upgraded headlight
If you are curious about any other 3rd gen lights let me know, ive owned em all... lol
The Pope
Gilbert, AZ
So still happy? I have $200 for a headlight upgrade, what do ya do?
chazwel
I am looking to upgrade my ordinal headlight assembly. these look good but this post is 4 years old. Dam. I will keep reading to find an updated post. if you have bought some recently please share if you like them or not. Thanks.
tidefan1967
Summerville, South Carolina
The Demon Hemi dude hasn’t been seen in two years but Cornelius is still an active member so I’m sure he’ll get back to you pretty quick.
corneileous
corneileous
Podunkyville, OK
Sorry it’s been so long getting back to your post but I just now saw that there was one. I guess the new reply notification for this thread ain’t working or something but yeah, everything worked out really nice except for the fact that I ended up having to buy me one of those brite box kits that allows you to modify your headlight system so that your low beams stay on with your high beams because my only complaint about those headlights was the high beams weren’t worth a crap. It was how they had the lenses set up because when just the high beams were on, it’s like you took a really bright flashlight and duck taped it to the center of the hood. They put a lot of light down the road but there was no scatter of the light towards the edges of the road at all so, hooking up that brite box made my low beams stay on with the high beams and it helped out tremendously.
I had great highbeam light for going down the road and then my lowbeams staying on did their job really well of illuminating the sides of the highway.
corneileous
corneileous
Podunkyville, OK
I sold the truck in March 2018 that those lights were bought for but when I still had it, I loved them a lot. Like I told the other guy, after modifying the headlight system so that the low beams stayed on with the high beams, they worked fantastic. I even got a little creative with the white LEDs and with the CCFL‘s to where I made those like a factory vehicle where they came on during the day and stayed on with the headlights by using a regular ole five pin, I think it was, relay and had the power tap tapped into a circuit in the fuse block that was only powered when the ignition was on. I even upgraded the turn signal bulbs to LED so what was left was a pretty nice set up in my opinion.
