FCM querry? Flying Incognito.
NewRamUser02
4.7L V8
My Ram 02, 4.7, V8 suddenly lost almost all exterior presence. Only the low beams and park lights work outside. I have no high beams, no horn, no wipers, no tail brake lights and no temp display at the overhead console. I found out the culprit is the FCM. Question: Do I do the replacement myself or do I let the dealer have at it?::hmm::confused::whymewhyme:
huntergreen
unless you have a warranty in effect, if you are capable, do it yourself and save the labor change. this assumes you had the codes read and are 100% sure you know what needs to be replaced.
