springfield1911custom@yah
- May 9, 2017
- 1
- 0
- 2003
- Magnum 4.7
I've onced with my dodge that the exterior lighting has a lot of issues. My story is when I closed up shop as normal, started up my truck and bam LAMP OUT yet again. Got home and found out I had to issues. Front driver side blinker would not blink but had power and rear driver side had no power (LED Taillights). First I looked at the rear. Come to find that the plug just was loose and not connected. Simple fix electric tape around connection. Moved to the front. From the outside, bulb seemed fine and working until I pulled the bulb out. Corrosion on one end of the bulb causing a poor connection. Corrosion also inside sock. Cleaned socket out and installed new bulb. Everything back to normal for now. Hope this experience will help someone someday.
