Headlight alignment
EWC88
Southern NJ
Think my headlights are missed aligned ever since I added the lift. How do you the proper height and everything it's suppose to be at?
I need to go somewhere that is close to dead on level to see how they are aimed and to adjust, is there a certain distance to be from a wall to do this appropriately?
Sohc1997
5.9L
25ft, that's what I used to adjust mine!
JPT
NY
2015 Big Horn
I have projector HID's, what I do is park behind a car about 5-6 car lengths (to the right, on a one way), then I make sure the sharp cutoff is below the side view mirror so it doesn't blind anyone. Then I drive around and slightly adjust up (if needed) if I can't see far enough ahead on the highway.
I have never had anyone flash me with my HID's on my stock height 4wd truck.
JPT
NY
2015 Big Horn
How do you adjust the height? Is it like the 4th gens?
There are two adjusters around the headlight housing, they will move them up and down. Pop the hood up (you need it up to see and adjust).
