justin13703
I find it extremely aggravating how when you turn on high beams, it shuts off the low beams and the fog lights. You actually have worse lighting with high beams on because of this. On my previous truck you could give the fog light relay ignition power and they would come on whenever you wanted, including with the high beams. Has anyone done anything similar to keep lows and fogs on with high beams? Or even just the fogs would help. Keep in mind this is an 08 with the can bus system. I assume it won't be easy because of everything being computer controlled and the TIPM.
