Hey all,
I haven't been fully active on this forum lately, but two weekends ago I installed Spyder Halo LED headlights on my 2005 Ram 1500 SLT.
Spyder part number for these headlights is: PRO-YD-DR02-HL-BK
The outcome was very nice, and the wiring was pretty simple.
There were two large black wires, which needed to be spliced into two more smaller black wires. Once this was completed you then took a separate piece of wire and connected one end of that wire (I soldered) to the 4 black wires. The opposite side of the wire is connected to your parking light ground wire using a quick splice.
There are two large white wires on each side which need to be spliced into two small red wires. The same procedure is needed with a separate single wire, and once that has been completed you quick splice the other end of the single wire into the parking light wire, not the turn signal wire. I used a multi meter to determine which wire was for the parking light, and which was for the turn signal.
