LED headlight problem
Wheeler10
I bought OPT-7 H-13 LED headlights for my 2007 Ram 1500 and when I turn them on they blink four or five times when the engine is on. They will work perfectly when the engine off. I bought a TURBO SII Pair 9008 H13 LED Headlight Canbus Wiring Kit Computer Warning Error Free Plug & Play Anti Flicker Resistor Canceler Decoder and it did not change anything.
07MegaCabRam
Chandler, Arizona
6.7L CTD
The TIPM doesn't monitor the truck unless it's running. Why the lights will work perfect when the truck is off. Does the canbus wiring kit include a relay or a resistor?
Either way should work if properly wired.
W
Wheeler10
Yeah it says it comes with a resistor. The kit said "simple plug and play" man it's frustrating!
