That looks good. Any more pictures?
Sure, here are two more from today. You'll have to forgive the truck not being quite as clean as that other picture! Here you can see how it looks with the hood up and how much of the radiator/AC heat exchanger is obscured. Operating temps even while towing are no different which is nice.
In this second one you can see how tight the tolerances between the bar, mounting tab and grille assembly are. It's cozy, but there's no contact between anything that shouldn't be touching. The other thing to note, my phone is aimed up slightly which is why the horizontal grille slat looks to be covering the first row of leds. Light output is probably 90 or 95 percent of what it is with the hood up. This mounting option keeps it stealthy, and makes my bar harder to steal!
Link to larger version of those two photos.
