OnSale
5th Gen Crew
- Nov 12, 2016
- 3,218
- 1,723
- Philadelphia, Pa
- 2020
- Hemi 5.7L
Ok so I ordered a 32" LED bar and 4 4" led pods. I also have 4 led strips in my bed already wired up.
I want to wire this up THE RIGHT WAY. I'm trying to get everything ordered so I have EVERYTHING and I don't have any surprises during the install.
The Lights I Ordered - :
• 32" 180W LED Light Bar - (Mounting In between Tow Hooks)
https://www.amazon.com/gp/aw/d/B01FJKTT5C/ref=ya_aw_od_pi?ie=UTF8&psc=1
• (4) 4" 18W LED Pods - (2 In Fog Light Holes/2 Behind Grille) https://www.amazon.com/gp/aw/d/B00FWD83RW/ref=ya_aw_od_pi?ie=UTF8&psc=1
• (4) 8" Pilot Automotive 10,000K COB LED Strips (These are already installed in my bed, just looking to run them to the Fuse Block instead of directly to the Battery)
https://www.pepboys.com/product/details/1318575/00111
Wiring/Hardware That I Ordered -
• Full 40AMP Wiring Harness For 32" LED BAR (Comes with Relay, Inline Fuse, Rocker Switch etc) -https://www.amazon.com/gp/aw/d/B00PTQOF4W/ref=ya_aw_od_pi?ie=UTF8&psc=1
• Full 40AMP Wiring Harness For 2 LED Pods (Comes with Relay, Inline Fuse, Rocker Switch, etc) - https://www.amazon.com/gp/aw/d/B00QYIZ890/ref=ya_aw_od_pi?ie=UTF8&psc=1
• Full 40AMP Wiring Harness For 2 LED Pods w/o Rocker Switch (Comes with Relay, Inline Fuse etc) -https://www.amazon.com/gp/aw/d/B00SYCR8HY/ref=ox_sc_act_image_1?smid=A15H3UKRB6RHF9&psc=1
• LED Fog Lights Rocker Switch (for 2nd set of LED Pods) (Blue) - https://www.amazon.com/gp/aw/d/B012WH6QV0/ref=ox_sc_act_image_2?smid=A15H3UKRB6RHF9&psc=1
• 6 Circuit Fuse Block (Comes with Cover) -https://www.amazon.com/gp/aw/d/B01GV78UP2/ref=ox_sc_act_image_3?smid=A15H3UKRB6RHF9&psc=1
• Rigid Industries 02-08 LED Pod Fog Light Brackets - http://m.ebay.com/itm/02-08-Dodge-Ram-Fog-Light-Brackets-LED-Rigid-Baja-Designs-2002-2008-/192037741619?txnId=1335825041009
Now, one of my first questions is, Should I order this aswell? - 150amp Manual Reset Circuit Breaker - Should I order this circuit breaker? If so, is 150amp the correct one? Or should I order the 100amp or 200amp?
My next question is, is this list everything I should need to hook this all up? If I need anything else, please let me know.
P.S. I know pretty much everything about wiring stuff. How to solder, in line fuses etc. BUT, I dont know the order in which to hook up the fuse block and circuit breaker. Does the power and ground from the switch (that normally runs to battery) go to the fuse block first? Or the circuit breaker? I'm trying to figure out the order, and if it's switch -> fuse block -> circuit breaker-> battery. Or if its different, please let me know.
Thanks in advance for any help, like i said I'm new to installing fuse blocks and circuit breakers.
