dsurmanek
I know at least some of this is probably already on the forum, but can't seem to find these specific answers.
I am looking to make some custom headlights for my '08 Ram 1500. I have stock headlights, but the lenses are quite scratched and I would like to have some time to work on this, so I would like to buy a set to work on while still having my stock headlights installed on my truck.
Overall I'm looking to paint the housing black (the rest of my truck is blacked out), retrofit HID projectors, add oracle SMD LED Rings, shave the turn stalks, and possibly switch/paint/tint the side amber reflectors.
For the retrofit, I'm looking at the BI-XENON MORIMOTO MINI STAGE III KIT (H1).
Oracle rings I am planning on getting ORACLE SMD Halo Kit.
I can't decide exactly what I want to do with the side amber reflectors:
Quick questions about painting:
Where would you recommend buying new replacement headlights that will fit both the projector kit and the Oracle rings?
If there is a 'How-to' for the retrofit specific to the 2007-08 headlights I would really appreciate a link.
Thanks so much in advance for your help!
p.s. I've never done this before (obviously) but I love to customize, and I'm sure I'll figure it out, just need some help getting started and making sure I get the right supplies. Excited to get some answers so I can start working and post pictures.
- What's the difference between the "Morimoto 3Five (35w)" and the "OEM Denso w/ AMP Conversion" ballasts?
- What's the difference between the Morimoto 3Five and the Morimoto XB35 Bulbs?
- The Morimoto XB LED Halo - will that fit behind any of the shrouds? Also, can I just wire those together with the Oracle Rings and have 2 sets of halos?
- Can't seem to find a good example of the difference between 4300K, 5000k, and 6000k
- Will this kit fit directly into the stock headlight housing without any cutting? If not what needs to be cut?
- Is there anything else I will need that's not included in this kit?
- Any other brand/model I should consider instead?
- Will these require MULTIFUNCTION Remote Control no matter what?
- How do I wire these so that they automatically turn on and off with my truck?
- Is there a way to tint them so that they reflect but look black?
- Where can I buy clear replacements? (so that they aren't such an eye sore)
- Are either of the previous options (or painting them with the housing) legal?
- Should I try to strip off all of the chrome coating before painting?
- Would you recommend using a clear coat? (I live in sunny Arizona)
- Any brands that will work better than others for painting the housings and shrouds?
