ramhunter9
- Jun 25, 2010
- 24,464
- 975
- 2012
- P-Star Jeep Wrangler
Oops !! ....
I asked around , because of the different materials metal hood and fiberglass scoop, that was a no go. body filler would crack, too much expansion and flex, Yeah the rvt I used has silicone, but I plan too go over that with a paintable product. Just haven't found it yet, I may try seam sealer, I dunno yet. But the main thing is the seam is down to almost nil. Thats the point here for now. I may have it detailed professionally Because it (the truck) is so far gone. It has never been taken care of, since day one. I'm gonna try and do it my self. when the weather cooperates. Btw I used 3m tape, stuff works good ,if applied according to the directions.
Bill, So you had a reaction or just bad atonimization Buddy, cause you usually gotta either top coat within 4 hours or wait 3 Days for the clear when using spray bombs?
You should be able to fix it no probs but will have to mask off most of the hood.
Good Luck!
500? see should have bought a hood from the beginning...
If you do bring it to a body shop then don't take it to maaco. Maaco may be the cheapest but there is a reason why its so cheap. Maaco only does single stage which means the paint and clear are all mixed together and sprayed at the same time. It wont be very shiny and over time the paint will come right off. Make sure where ever you take it does double stage.
