semi horns
jhemi
wisconsin
got these for free!!! what kind of compressor tank set up should i use, what all do i need to get them going, thinking of using two shorter ones in grill and longer ones under the bed
quietpeen
2021 TRX
Hellcat
nice, that's awesome and you can't complain with free.
jhemi
jhemi
wisconsin
do i need relays and solenoids or just compressor and tank and a way to let air release to the horns
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
Mine has a solenoid valve in between the horns and the tank, thus, a way to release the air from the tank when power is given to it. But you can probably do it however you think will work.
Just make sure it can handle the PSI.
quietpeen
2021 TRX
Hellcat
i would say you would hook it up the same way others have their train horns hooked up so the members that have them could possibly steer you in the right direction, and like BlackedoutHemi said.....make sure your psi is not too high
jhemi
jhemi
wisconsin
il have to look up the rating they are made buy hadley they might make a complete kit minus the horns ill have to check into it
BlackedOutHemi
DFW, Texas
2012 & 2012
I would honestly go with the same setup I've got going on with those 4 horns. It has a 150PSI compressor hooked up to a 2 gal tank, with a high pressure tubing ran to the solenoid valve on the frame (Which is rated to handle up to 190PSI, a little leeway), and then tubing rated to handle the PSI at that point to each horn. Its EXTREMELY loud.
ROKTMAN
Fairfield OH
I have a 200 psi Viar 480 C compressor and a 1.5 gallon tank with 1/2" lines.Depends on the mounting location(bed) on the tank.I went with the 1.5 so I could mount everything under the air damn.I get a 7 second blast so you might want to go 3 gal or even 5 if you want a longer blast before refills.I have a 230 psi pressure switch and an inline solenoid.
Mine is 157 db and loud.
Hope this helps.
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
This is how mine is hooked up, but I just have a cheapo setup
txram956
