Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > Exterior
Exterior
Srt hood malfunction.
This is a discussion on Srt hood malfunction. within the Exterior forums, part of the 3rd Gen : 2002 - 2008 category!
Well today I was racing my friend for a short 25 roll. I don't think we even got to 50 ...
Like Tree4Likes
Sponsored By: BAK Factory Outlet
Reply
Old 08-08-2013, 05:09 PM   #1 (permalink)
PCA4208's Avatar
Ram Year: 2006
Engine: Hemi 5.7
Default Srt hood malfunction.
Well today I was racing my friend for a short 25 roll. I don't think we even got to 50 then I saw something fly off from the front of my truck. So I pull over and sure enough it was the insert in my SRT-10 hood. Luckily it flew off and landed in a grassy median, paint up. No scratches or anything! So now I'm stuck with a huge hole in my hood until I figure out how to re attach this. What happened is that the clips that hold it into the hood at the front, sheared off the insert. So has anybody dealt with this before? And how did you fix it?
AK_Armendariz likes this.
Sponsored Ad
Register to remove this ad.
__________________
2006 Ram 1500 QCSB HEMI
Pretty much all stock... For now
University of New Mexico 19' Sigma Chi
PCA4208 is offline   Reply With Quote
Old 08-08-2013, 05:40 PM   #2 (permalink)
HemiLonestar's Avatar
Ram Year: 2003
Engine: 5.7 hemi
Send a message via AIM to HemiLonestar Send a message via Yahoo to HemiLonestar
Default
Unfortunately it is a piss poor design for attaching it. Two of mine broke, but I was able to use screws up from underneath to hold it in place. Maybe epoxy something to act like a screw? I wouldn't trust it, I would start looking for a replacement. Sucks because new ones are like $240 last time I looked.
Christ, it's worse than that....
SRT 10 Dodge Truck Hood Scoop Insert Complete Kit New Mopar | eBay
This is just the bezel itself
moparonlineparts.com
MOLDING-HOOD
Make: Dodge | New Part#: YL23TZZAB
List Price: $342.00
Your Price: $235.75
__________________
2003 Ram 1500 QC Hemi Lonestar "Big Red" & 2006 Charger R/T "Little Red"
SRT-10 suspension, brakes and interior parts, Circle D, 1 ton trans cooler, Bilsteins, Superchips, AiRaid, Taylor shorties, McGaughy's shackles, Borla cat-back, Daytona lip, tow mirrors, SRT-10 hood.
HemiLonestar is offline   Reply With Quote
Old 08-08-2013, 05:46 PM   #3 (permalink)
PCA4208's Avatar
Ram Year: 2006
Engine: Hemi 5.7
Default
Crap, that's what I was dreading. So could I get those pins that sheared off, plastic weld them back on, then use a bit of threaded rod in the four locating pins, and use that to bolt it on? I really don't feel like getting a new one, then having it painted and all.
__________________
Old 08-08-2013, 10:58 PM   #4 (permalink)
PCA4208's Avatar
Ram Year: 2006
Engine: Hemi 5.7
Default
Bump for anybody that can help.
__________________
Old 08-09-2013, 11:16 AM   #5 (permalink)
HemiBabe's Avatar
Ram Year: 2004
Engine: Hemi
Default
Oh man, that sucks!
Mine was barely hanging on by a thread too, I had a local shop plastic weld them back on, and so far it's worked pretty good
__________________
http://i957.photobucket.com/albums/ae60/HemiBabe88/b2f1e937-fc99-4c11-9102-74da5c2323f2_zpsd9db664c.jpg
HemiBabe is offline   Reply With Quote
Old 08-09-2013, 03:00 PM   #6 (permalink)
PCA4208's Avatar
Ram Year: 2006
Engine: Hemi 5.7
Default
Yeah. That's what I'm picking up tonight. And some threaded rod. I'll show you guys what I'm thinking of doing in a bit.
__________________
Old 08-09-2013, 07:59 PM   #7 (permalink)
PCA4208's Avatar
Ram Year: 2006
Engine: Hemi 5.7
Default
Alright epoxy is setting. Me and my dad decided to run a bead of silicon sealant around the perimeter of the insert. He has some pretty serious stuff that holds our aluminum sink in place, so I'll do that too.
__________________
Old 08-09-2013, 09:32 PM   #8 (permalink)
Ram Year: 2007
Engine: SRT 10 Viper Motor and Tranny
Default
That is one reason I went with an aftermarket hood for my truck when I had to replace the motor. It is a true ram air style that actually works to force air into the intake. Here is a link to where I got the one I have:
https://www.ramairhood.com/store/scr...?idproduct=40#
I also got their airbox which mounts right on top of the intake and connects directly to the throttle body.
MegaMouseGW is offline   Reply With Quote
Old 08-09-2013, 10:21 PM   #9 (permalink)
Ram Year: 2004 Dodge Ram
Engine: 5.7L
Default
bummer man. still my fav hood though.
__________________
_-under construction-_
2004 5.7L Dodge Ram RCSB - Sold
TheSatinPumpkin is offline   Reply With Quote
Old 08-09-2013, 11:07 PM   #10 (permalink)
Ram Year: 2002
Engine: 4.7
Default
You know I saw this thread yesterday but I don't remember seeing the pictures so I didn't quite understand what you were talking about.
I really hope the epoxy works but I don't think so, if it doesn't work then look at the piece and see if there is "ABS" molded in the part. If so then you're in luck because you can chemically weld them back on. You will need something called Ambroid Pro-weld. Go to a good hobby shop, they should have it. This stuff will literally melt the two pieces of plastic back together so go easy on how much you use. Put the pieces together and using a toothpick drizzle the chemical over the seam. It will wick in through capillary action.
I build models as a hobby and use it alot. I also used it to repair a grille I got off of CL for dirt cheap because it had two cracks. Now it's good as new.
Silicon sealant around the perimeter is a good idea. It will give it a bit more hold.
Good luck.
Don
devans is offline   Reply With Quote
Reply
Tags
broken hood scoot, srt hood help, srt hood scoop, srt scoop broken
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Random Misfire,Misefire 4, Ign Coil Malfunction, bad o2 sensor SparkyOne23 Engine & Performance 0 05-19-2013 07:10 PM
Cowl Hood/Hood Scoop 3rd Gen HemiChick Exterior 20 04-29-2013 06:24 PM
New hood for the Ram albertschmitz Exterior 16 04-29-2013 04:05 PM
Yet another SRT hood... HemiLonestar Exterior 12 03-16-2013 10:15 AM
Srt 10 hood dodge15004x45.9 Wanted 16 12-10-2011 10:51 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
