Switchback turn signals
OLEred03
To run the switchback turn signals will I need to have 2 separate load resistors, one for turn signal and another for parking lamp?
ramportin1
Sickest member here
Oregon
Just one resistor per bulb/harness.
OLEred03
OLEred03
So would I splice into the turn signal wire on the parking lamp wire?
Demon-HeMi
Houston
2003, 2003, 2008, & 2013
(2) 5.7 HEMI, 3.7, & 3.6
no splice it between the ground and the turn signal wire, parking lights require nothing
OLEred03
OLEred03
Okay, I appreciate the help. I should be getting them sometime this week.
OLEred03
OLEred03
Okay, I appreciate the help. I should be getting them sometime this week. I need to bolt the resistor to something metal correct? And I don't like using the butt splices, would it hurt if I soldered it it place?
Demon-HeMi
Houston
yes bolt it to metal, the resistors get pretty warm, and soldering it in place is the best way to do any electrical connection :favorites13:
