Tire question. Pic request?
Jak259
New Jersey
Hello, my truck came with 17's oem. I am in the process if getting some custom 20's. I was going to put the 275/60/20's on it. Eventually I would like to do the 2/4.5 drop. My question is will those tires still fit once dropped? Don't know when it will be dropped so I was trying to fill the wheel well as much as possible for now. May just add level kit in the mean time. It's a 2005 2wd qc. Been looking for some qc's dropped with that size tire if anyone has any.
Thanks everyone!
HemiBabe
DFW
Well, I'm not a quad cab... but this may help anyways.
I'm pretty sure I'm runnin that size tire, I have the 4th gen OEM 20s.
I'll have to check the tire size after work, but I have no issues at all with the 2/4.5 drop.
picture.php
HemiLonestar
MD
I have 305/50/20's, they are the same height is MY oem size (for 03 was 275/50/20). Little shorter I think.
DSC01569_zps00c626d0.jpg~original
Jak259
Jak259
New Jersey
Thanks a lot. Hemilonetar where did you get the daytona front lip?
moparman
Woonsocket, RI
2016 Ram 2500
I ran that size on a 2/4.5 drop and had no issues. Wore those out and went to 305/50's and went down to a 3/6 drop and it rubs once in a while, but living in new england itll always happen
Sent from my Galaxy S3 using Tapatalk 2
SublimeRT
Does it rub in the front? On the fender lips? I have a 2/4.5 on mine with a 275/55-20 and mine rubs there sometimes. I would like to go lower though.
moparman
Woonsocket, RI
2016 Ram 2500
It rubs the sway bar going slow with the wheel full lock. The fender liners are removed and the fenders are rolled and flared a little bit for clearance
979dodge
I have a 2/4 drop on my 2004 QC and i would hit on my 275/60's.(tore up both inside fender wells!) I just recently switched to 275/55's and haven't hit yet. Sorry no pics but I also like this look better than the old set up. Maybe shocks have something to do with in front?
