Tire rub?
bulldog1500
I have a 08 ram 1500 bighorn quad cab with a 5.7 hemi, stock suspension.
If I went with 17x8 rims (-12mm offset) and 35x12.5 tires, will I have rubbing problems? And if so, how severe?
Sent from my SM-S920L using Tapatalk
ramportin1
Sickest member here
Oregon
You will definitely rub, and pretty bad id guess. I had 35x12.50 MT's with 2.5 level and still rubbed on flat ground not even full lock turn. On a decline at full lock it would sound like it ripping the bumper off lol
bulldog1500
bulldog1500
Do you know what kind of off set you were running with these?
ramportin1
Sickest member here
Oregon
Originally the stock 20" rims (07 ram 1500 BH) then after that threw on 2" spacers which helped a bit but still rubbed on full locks. Cut out wheel liners and that helped some more. After that I changed up everything. And this was with 2.5" level
ramportin1
Sickest member here
Oregon
O but I'm not sure what offset those stock rims are. They were the 20" ones with the chrome plastic covers
ramportin1
Sickest member here
Oregon
bulldog1500
bulldog1500
Ok, thanks for the info. Do you know what the max size I can run with a -12mm offset? With stock suspension?
ramportin1
Sickest member here
Oregon
That one I don't know, sorry. Hopefully someone else can chime in. I'm assuming you are talking about a MT tire or a aggressive AT?
bulldog1500
bulldog1500
Yea, looking at getting the toyo open country at 2 extremes.
ramportin1
Sickest member here
Oregon
Ok, I started talking before verifying so wanted to check.
bulldog1500
bulldog1500
Well if anyone is interested, you can fit a 35" tire on these trucks with a stock suspension. -12mm offset wheels, 17x8.5 .... 35x12.5 toyo open country at II extreme tire. They are real close to rubbing, but so far no rub! Most likely will level it.
ramportin1
Sickest member here
Oregon
Wow, I guess I stand corrected lol. I rubbed bad with mine but I suppose it musta just been from the gnarly MT treads. Looks good man
justin13703
MD
My 35x12.50s don't rub at all except for in reverse at full lock. -12 offset wheels, truck is 4wd and leveled. They are trail grapplers btw.
ramportin1
Sickest member here
Oregon
That is not the tread pattern of trail grapplers, TERRA grapplers use that tread pattern. I run trails, they have a much larger tread and and sidewall bite. That would explain the no major rubbing issues.
ramportin1
Sickest member here
Oregon
That's a trail grappler with 35k miles on it, you can see the size difference in the treads, sidewall and pattern
blackbeautyhemi
Lewistown, PA
I believe justin was stating he has trail grapplers not bulldog.
ramportin1
Sickest member here
Oregon
Blackbeauty, ahh yes you are correct. re reading I see I mixed people up, my mistake.
Johnnymac2k6
Ohio
2007 Ram 1500
MY 35 12.5 r17's rubbed with a 2 inch spacer at 3/4 to full lock on any grade other than flat. That was with a 2 inch level also. rims are 8.5 with zero offset.
Here's my build thread if you want to see how i had to fold the pinch seams over. scared the hell out of me as everything was new on the truck when i first heard it. sounds like the front end is coming apart.
http://www.ramforum.com/f17/3rd_gen_ram_pre-runner_appearance_budget_build-101397/
