I got under the front of my truck to find out why the fogs won't turn on....simply some burnt bulbs, or who knows.
I found the bulb on the passenger side to be burnt out. The bulb on the drivers side was good, but the wires going to the plug were cut, obviously why it wasn't working. I stripped the wires (very hard because there's about 1 inch of wire to work with on the plug side of things, probably should try to find a new plug somewhere with longer wiring) and twisted them together, thoroughly wrapped with electrical tape.
Now the drivers side light works...the passenger bulb is still burnt, haven't replaced it yet....but the drivers side only comes on if I tap the fog light lense. Any ideas what could cause that to happen? It makes no sense to me.
