Wind shuttering noise on top of front doors-2008 ram.
xtremewlr
Tucson, AZ
Installed the backer rod on my truck this afternoon. Home Depot where I'm at had 3/8, 1/2 and 5/8. I went with the 5/8 and will say it's maybe a little too thick but we'll see if it crushes down a little over time with the doors closed. If not, then I will switch to the 1/2" stuff.
corneileous
corneileous
Podunkyville, OK
2018 Ram 1500 Limited 4X4
I would think you would be fine with the 5/8ths stuff. My hardware store only had it 3/4 and 7/8ths, and I went the 3/4, it crushed down fine. Actually kinda felt like it was a bit small but so far it's been doing the trick.
Did you stuff yours inside of the weatherstripping or did you apply it like in the picture I posted where it goes all the way up top between the cab and the stripping?
xtremewlr
Tucson, AZ
I did like you have yours and tucked it behind the weather strip. I think it would be a real pain to try and get it to slide into the weather strip even though that would probably look a little better and protect the foam over the long term. But the stuff is cheap, $5 for a 20' roll which is way more that you need for both sides of the truck, even on a quad cab.
corneileous
corneileous
Podunkyville, OK
Yeah, if you could get it on the inside, that would probably be great as far as making the backer rod last longer but like we said, that stuff's cheap...lol. Especially for as much as you get for as little as you pay for it. I got more than enough left over for another new application for anywhere between now and this winter if I'd wanna replace it on an annual basis but another thing, even if you were able to successfully stuff that stuff inside the cavity of the weatherstripping, you'd probably have to readjust your striker bolts so your doors will shut...lol. I know, been there, done that..lol.
I haven't even checked mine in while to see how it's holding up to the exposure of outside but hey, if yours is anything like mine, the weatherstripping does a pretty good job of smashing the rod just enough to hide it from the sun's rays.
